Well as the economy continues to remain stagnant and isn't getting better, most of us are feeling the pinch so this is why I kinda started this thread.
One of my main questions is concerning the rear trail arms or control arms. Is it possible that the pinion angle could be out of the proper alignment as a result of our stamp steel rear control arms? I would think with four different points of contact on the rear end, it would be hard for the pinion angle to be out of alignment.
So what would be the benefit to say welding up the control arms? I've seen plenty of the aftermarket control arms that are adjustable and non-adjustable. Is it worth buying these aftermarket ones or is it simply cheaper just to weld up and box my stock control arms?
Another thing I wanted to ask that after I lowered the front end of my car, the lower front control arms are angled slightly upwards. Is this a potential problem? If I lowered the rear end with lowering springs, would this throw the front end out of alignment?
One last thing, what are the pros and cons of solid mount body bushings compared to say poly bushings? I know I had a started another thread on body mount bushings, but it kinda seems more logical to have solid mounts to eliminate body role.
Thanks for the help guys.
