Im replacing all of the front end. this cutlass was in a barn for tears with only 42k, but all the rubber is dried out. so while I'm doing that, I am trying to find out what I can on the electrical part, I would like to use all the same gauges. The car is mint and I don,t know what I can use and what I can,t..Welcome - I'm going to suggest you get everything together before taking yours apart.
Buick 3.8 to a SBC there really isn't anything that will carry over to the new engine and you have to start by changing the frame mounts to SBC.The car is mint and I don,t know what I can use and what I can,t..
I got them on the way. I ordered a turn key 383 stroker everything is gonna be ready to go I’m just trying to figure out all the wiringBuick 3.8 to a SBC there really isn't anything that will carry over to the new engine and you have to start by changing the frame mounts to SBC.
From where?I ordered a turn key 383 stroker everything is gonna be ready to go I’m just trying to figure out all the wiring
Skip white performance, Not far from where I liveFrom where?
Your going to need the brackets for your accessories, fuel delivery needs to be re-routed, the trans has a different bolt pattern, and your going to have to decide on exhaust which could mean a new trans crossover mount. It would be nice to know the specs of the 383 which might require a converter, rear end gear change. Depending on the power you plan on having a rear end upgrade might be in order and a bigger radiator will be needed. I assume your going none computer control so you can remove that complete harness.
