I'm trying to get everything together to install cruise. I would assume that in a Monte Carlo that the cruise control bracket is installed using one if the intake manifold bolts? Being that the vortecs bolts go up and down and not on an angle, I would assume the bracket from a Monte would not work. Unless its bolted to something else? Anyhow. I did purchase a cruise control harness from a Monte SS in the case that I would have to swap the OLDS 307 one out. Question is, has anyone done this swap? If so, what did you use? On the cutlass, it had the cruise module mounted to the top front of the engine. However, on my Grand National, the cruise module was installed on the drivers side plastic fenderwell. Low and behold, the drivers side of the cutlass has the exact same bosses to install a module there. What have you all done?
