Sway bar brackets threads stripped out
fly_25
136
67
Need some advice on how to fix this. I was installing my front sway bar and when I was torquing the bolts for the frame brackets the bolt let go and took all the threads out the frame with it. Does anyone have any experience with this? Or this kind of repair? Metal seems too thin for a helicoil. Thanks!
ELCAM
1,121
1,266
On the passenger side there are holes in the frame for the idler arm bolt access you should be able to put nuts on the bolts with needle nose pliers.
On the drivers side you will need to pull the bumper and shock and insert the nuts from there. One trick is to use metal strapping used to secure pallets. Tack weld a nut to the a piece of strap and slide it into the frame horn.
64nailhead
Goat Herder
Dec 1, 2014
5,697
12,185
Upstate NY
Drill and tap to the next larger size. You can use metric as well when finding the next size larger.
Reactions: 6 users
565bbchevy
9,611
12,670
Michigan
I have drilled out the frame and re tapped it in the next size up and then opened up the holes in the sway bar mount to that size and used Allenhead bolts to give the extra clearance needed because of the larger diameter.
I also do this in 1/2" for the frame mounts on the jounce bars
Reactions: 4 users
Supercharged111
4,924
7,702
Colorado Springs, CO
Better bring those forearms to set the things.
565bbchevy
9,611
12,670
Michigan
DJHull
255
232
Lansing, Mi
This worked great on the passengers side.
fly_25
136
67
Okay so to finish this story off I ended up using rivet nuts and installing them with a diy tool, installing them was a pita but they're in, and the sway bar is installed. Thanks Everyone!
