Sway bar removal or not ????'s
dickeymoore
924
Atlanta,Georgia
When removing or installing a G-Body 7.5 rear end is it necessary to remove the sway bar from the trailing arms or can it stay put in place to install the rear end?
500/600
1,167
2,638
West Virginia
You’ll probably not get the lower arms back in place with it still on. Remove it.
melloelky
4,160
9,568
mass
if you're removing the arms with the rear end then they can stay,if you're planning on just rolling the rear out wheels and all it'll be fine.if you're leaving the arms on the frame and removing just the housing with out the wheels(say with a jack under it and dragging it out) then remove the bar.
69hurstolds
8,195
17,594
Then remove the bar if you're leaving the control arm fronts still attached.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
if you do not remove at least one side of the bar you'll end up struggling and cursing to get the lowers lined up to install the bolts
