sway bar
scarborough
307
66
looking to improve the rear suspension on my 87 cutlass i found this on summit if my search was correct its for 2000 blazer 2w driver. for $193.99 i know some member are going to a salvage yard to find this setup for their gbody . so is this basically the same setup. thinking of purchasing this for my build i wouldn't mind spending 200.00 for all new parts. everything in my area is covered with rust
QA1 Sway Bars 52875
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Looks like a good deal
81cutlass
4,649
13,565
Western MN
LewG
20
8
Florida
I have a stock rear sway bar I'll be selling for $40. Where are you located? I'm in central Florida if you can pick it up. Shipping might be high.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
That is the same bar they list for an 82 to 02 F body. I have a GTA F body rear sway bar and the bar is too wide for a G body so I had to heat it up and bend in the arms about 1.5" on each side
shoedoos
406
403
check out Hellwig's G-body offering.....last time I looked it wasn't much different in pricing and has adjustments in both the bar and mounting points....
airboatgreg
2,867
3,115
I went with Hellwig and am very happy with it. World of difference
Longroof79
Oct 14, 2008
12,176
9,778
Gainesville, Fl
If I recall correctly, the end link mounting points to the body had to be drilled. Steve described how he was able to mount his. Can you explain it again, Steve?
Is the Blazer rear bar the same length as an F-body bar?
Never mind, Steve. I found the thread. https://gbodyforum.com/threads/sway-bars.69567/#post-640588
