My Hedmans are a different design, mine don't hang down as low and I don't remember a pipe interferring with the starter. What mode # are those headers.
as for starting I have it neutral, I don't not start it with the clutch in cause that puts pressure on the thrust bearing which will wear it out prematurely. It's a bad system GM has when the clutch has to be pushed in to start the car. Corvette and Camaro guys complain alot about thrust bearing failures
Thanks for the moral support. Looking at your pic below and what I can recall from seeing the header in my car yesterday, your header is pinned up against the control arm and allows room for the starter.
My header is NOT pinned against the control arm but is in the way of the starter.
Hedman must have changed the mold or something.
https://gbodyforum.com/attachments/20180123_181450-1612x1209-jpg.81279/
If disengaging the clutch is creating pressure on a crank thrust washer, then you need to do one of two things - move the transmission farther away from the engine or limit the clutch travel. The input and throwout bearing should NEVER put any type of forward force onto the crank thrust washers. Something is wrong in your setup if this is the case. Also, the clutch should be fully disengaged prior to the pedal hitting the a dead spot that is exerting pressure on either the pilot bearing or flywheel.
pontiacgp - sorry to disagree with you, but this is incorrect info. Fix the issue, not the symptom.
From Texas82GP Thread: "I bought a set of Hedman 68318's. They are the Elite version of the of the 68310's. "
Me, I bought the cheaper 68310's
No need to apologize if you disagree with me....but....
https://www.motor.com/magazine-summary/thrust-bearing-failure-prevention-analysis/
"In addition, on manual transmission vehicles, the use of starter lockout systems (where the clutch pedal must be depressed in order to start the engine) adds to the problem, since this places forward pressure to the crankshaft during starting, when there’s little or no oil lubrication on the thrust bearing surfaces. Bearing manufacturers have tried to address these OE-inherent problems by adding a fine dispersal of silicon to the bearing matrix and by designing angled ramp areas on the thrust faces that help to promote oil delivery to the thrust areas."
