T50 to T5 tranny swap
Discussion in 'General Discussion' started by DoubleV, Feb 10, 2018.
  1. 1983calais
    1983calais Greasemonkey
    Feb 26, 2015
    149
    94
    Tiffin, OH
    Indeed. The mount is level or parallel with the ground when the trans is tilted 17 degrees. The shifter also tilts towards the driver when the trans is mounted this way.
    When tha trans is mounted straight, not tilted 17 degrees, the mount is now tilted 17 degrees and the shifter is straight up and down.
  2. DoubleV
    DoubleV Royal Smart Person
    Feb 25, 2011
    1,974
    56
    48
    Cleveland, aka 'The Factory of Sadness'
    So it would seem an F-Body T5 would work if you fabbed up a wedge for the crossmember.
  3. 1983calais
    Feb 26, 2015
    149
    94
    Tiffin, OH
    A wedge of some sort would work indeed. I have a 6 cylinder t5 if you are interested. I see your in Cleveland. I am about 2 hours from there. Also a nwc v8 t5 as well.
  4. DoubleV
    Feb 25, 2011
    1,974
    56
    48
    I'm gonna hold off on buying anything yet till I do more research but I'll keep you in mind.
    Seems from all the pics I've seen of T50's including the ones in the service manual, the input shaft does not have 26 splines. Much less. That would require some more mods but not certain what exactly.
  5. 1983calais
    Feb 26, 2015
    149
    94
    Tiffin, OH
    The spline count really doesn't matter. A clutch change will fix that. You just buy a clutch with the proper spline count.
  6. 1983calais
    Feb 26, 2015
    149
    94
    Tiffin, OH
Loading...
Similar Threads - T50 tranny swap Forum Date
T50 to T5 swap revisited General Discussion Mar 11, 2018
monte carlos with manual tranny General Discussion May 14, 2018
what tranny is this General Discussion Apr 5, 2018
442 Tranny change General Discussion Mar 16, 2018
Lost 2004r tranny. General Discussion Jan 31, 2018
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
