GRAND PRIX Tach Help
85GrandPrix#1
5
Colorado
Hello all, I recently posted about some tach troubles. Well I have it all in the dash, mock jumper bar and everything. Signs of life, but no life. When ign is on, it jumps to zero, so I know it’s getting power. When I start the car, no rpm’s show up. I can tap the needle and it’ll go back to zero, but no rpm’s. Tried the jumper bar in both the 6 cylinder and 8 cylinder configurations and both had the same results. Anyone know what’s up? (Pic with volt guage to show engine is running)
79 GP 4 speed
447
535
Did you hook a wire up to the distributor?
79 GP 4 speed
447
535
I have 5 wires going to mine, one to battery, one to tach and 3 to the other plug. I have 3 plugs all together.
buick7332
350
589
N.E. Philadelphia area
The white needle tach is from an older Grand Prix. I don't know for sure but I can remember reading a thread on this site about the difference between white needle and orange needle gauges. I think 84 and up are orange and would need some modifications. Maybe someone else knows more about this and can chime in.
DSM
Feb 1, 2008
92
106
33
If the car originally had a clock then the circuit from the distributor "tach" terminal to pin 7 of the cluster plug (upper left, white wire) isn't going to be complete. Try temporarily running a jumper wire from the distributor to the tach pin on the gauge.
G-Body of the Month
12,156
9,762
Bingo! I was going to suggest checking to see if the white wire from the harness was connecting to the distributor.
