Tail pipes
H/O84
181
44
Does anyone sell 2.5 inch tail pipes that exit behind the rear wheel (H/O style) for a decent price? I cant seem to find any.
403Olds
532
421
South Central Ohio
I was pleased with the fitup of them, although I did have to cut the 45 degree slash on the tip to make it look factory. I didn't care for the squared off outlet. Didn't matter as I cut them after installation to make sure they matched.
403Olds
532
421
South Central Ohio
Your welcome, good luck with the install. I agree, the monte tail pipes look good on monte's and mustangs, but the behind the wheel is right on all the other gbodies.
timo22
550
1,072
St. Louis,Mo
403Olds, I was looking under my Malibu and was wondering if I would have a problem installing these tailpipes. I noticed your muffler were center exit and mine are outside exit. Do you think those tailpipes would clear my coil springs? Here is a pic of my car, Thanks, Tim
403Olds
532
421
South Central Ohio
Timo22, you should be fine, I had to bend mine a little since the mufflers are on reverse of how they are normally installed. I would have switched them around, but the muffler shop that originally bent up the exhaust, welded the hpipe together. I was surprised that the mandrel bent tailpipes added some power over the muffler shop bent up ones. Both were 2.5"
