Taillight problem-ideas?
clean8485
2,861
2,144
Ontario, Canada
I want to switch out the taillights on my '80 Malibu for 1981 taillights. I have the taillights and the 1981 taillight harness. I installed the '81 harness, and when I connect the battery, the brake and signal filaments in the 4 taillight bulbs come on steady and stay on. This happens as soon as I connect the battery, without turning anything on. The connectors on both the '80 and '81 harnesses look the same, the wire colours are the same, the connectors connect to the vehicle harness connector in the trunk the same. I've tried 2 different sets of bulbs with no difference. Any ideas? Thanks in advance.
airboatgreg
2,866
3,114
Emergency flashers may be on with a bad flasher
Brake lights stuck on
Bad turn signal switch
123
clean8485
2,861
2,144
Ontario, Canada
Doh!! I feel like a bit of an idiot. I've been changing the brake lines, master cylinder and power brake booster. The brake light switch is out of adjustment. Thanks for your help.
airboatgreg
2,866
3,114
Happens to all of us.
NEVER overlook the obvious and complicate the issue
