take off parts from my 87 monte project
Trader history for jakes87SS (1)
jakes87SS
jakes87SS
457
ohio
standard volume and pressure melling oil pump new --$40
305 HO air box with k&n filter, all ducting tubing and bracket tubing--$100
kickdown cable brackets with a vac line--$20
MR Gasket egr block off kit--$10
q-jet 4 bbl computer controlled model ---$40
claret seat belt holders off the seats with screws--$40
remote trunk popper kit --$40
powermaster 100 amp alternator -$100
stock trans shift cable with stock bracket $40
factory floor coin tray claret $40
ss center cluster oil,temp,volt, 80$
6k ss tach 80$
flex-a-lite black magic fan 3000 cfm 18 amp electric fan with controller and relays 160
working car phone 60
stock shift cable 50
adjustable fuel pressure regulator 120
kp components dual needle air pressure gauge for air ride 20$
oil pressure sender 10
stock 4spd gear indicator 50
driver side ball chiller vent 20
floor 2004r shift linkage 50
door vent 10
sway bar end links 10
claret ashtray 40
aluminum gauge trim rings 20
gauge cover face 10
trunk brace kit 40
2004r speedo cable 30
r4 ac hookups 40
coolant T 5
Stock sbc long waterpumps 20 per
stock sbc harmonic balancer 40
braided stainless lines for stock or blazer brakes 20
