Tall lower ball joint with drop spindles?
H
Hi-Fi
Oct 14, 2016
59
15
8
#1
Finally getting my car back on the ground and the front sits a bit higher than I expected.
Setup is Belltech drop spindles - Blazer conversion with bolt in hubs, Blazer brakes and such
Moog 5602 springs.
New Moog upper control arms
New Moog (stock) lower ball joint.
235/60r15 tires in front
I've heard that a taller lower ball joint will lower the front about .75". Any compatibility issues with what I have? I read some about it hitting its travel limit and damaging the balljoint, but I'm not sure if that applies to only a taller lower.
Thanks for the help again...if you have recommendations with brand or part numbers let me know.
fleming442
fleming442
5,541
6,165
I have basically the same setup with a similar problem, and am looking to do the same. I have 5662 springs, though. Currently, the car will bottom on big dips- maybe the term shouldn't be "bottom", more like "top out"- the top of the tire hits the inner fender. That being said, your situation will be more noticeable with those soft springs.
First, did you have the full weight on the wheels when you tightened the control arm mounting bolts? If not, loosen them up, then see how it sits.
My current plan of attack is to do the taller LBJs, stiffer 5664 springs, and a shorter 245/50-16 tire. My thinking is that the LBJ will lower it, the spring will stiffen it, and hopefully, a shorter tire won't rub as bad.
H
Hi-Fi
Oct 14, 2016
59
15
8
#4
All the control arm bolts are loose. When I put it on the ground I rolled it back 20' and forward to its original spot and rocked the car to make sure something wasn't binding.
pontiacgp
pontiacgp
Canadian Prime Minister
Mar 31, 2006
24,340
9,620
Kitchener, Ontario
#5
the 5602 spring is a stock G body spring so the car should have dropped 2" with the drop spindles. Do you have a picture of the car cause you may have the 2" drop but you were expecting more.
8
81cutlass
1,626
2,326
Western MN
#7
The stock springs are ~40 years old and likely sagging from the factory. A new spring might have lifted the car 2" to start with, and although 5602 is a stock spring, there is pretty wide tolerances and differences in mfg. processes between 198something and 2019. 2"+ from new springs and 2"- from the spindles is net zero gain
You can wait the summer and see if they settle, but they will settles 1/2" maybe? At least my 5660's didnt settle much.
The other option is to go with a 5660 or 5658 which is an S10 spring and shorter with a higher spring rate. Stock G body springs are long and low spring rate so they float the car. Unless you really want that soft ride, 5658's might be another decent option.
motorheadmike
motorheadmike
3,520
6,737
Ottawa, Ontario Canada
#8
Same here in the wagon: 2" drop spindles, 5664s, stock A arms, tall lower BJs, and needing a different sized front tire (245 or 255) from the 275s now... that and more negative camber via new UCAs.
H
Hi-Fi
Oct 14, 2016
59
15
8
#9
img_20190415_161740275-jpg.111220
That's a 235/60/15 tire.
To all - I knew the ride height was a complete crapshoot with how much I was replacing, but the car went up significantly, probably 2" based on old pics
It's a iron headed SBC with no AC, headers and no smog stuff. I didn't think it would be low, but that's a lot if wheel gap.
I'm looking at tall lowers (.5" drop) and possibly some different Moog springs. If I ever get larger wheels I'll look at tall uppers too.
pontiacgp
pontiacgp
Mar 31, 2006
24,340
9,620
Kitchener, Ontario
#10
That looks like a factory ride height, are you sure the spindles you have are a 2" drop?
Thread starter Similar threads Forum Replies Date
565bbchevy General Discussion 10
O General Discussion 2
S General Discussion 12
Mike T General Discussion 1
Similar threads
