Temp Gauge & Courtesy Lights Not Working, Related…?!
Ribbedroof
4,861
6,887
Wellston, OK
There should not be any sealant on the sender, as it grounds to the block through the case. Teflon tape or other sealers may inhibit that ground path.
G_RIDE_81
Oct 30, 2019
88
19
8
The broken one in the picture has been installed on the engine with no sealant for weeks now. Still not working in my case.
Ribbedroof
4,861
6,887
Wellston, OK
Ground strap to body from engine reinstalled after 350 swap?
G_RIDE_81
Oct 30, 2019
88
19
8
There is suggested diagnostic test that says if you ground the green wire which connects to the sensor while key is "On" and the gauge sweeps "hot" it means there is no break in the green wire leading to the gauge cluster and the gauge itself is working.
fly_25
136
67
I am having the exact same issues with my gauge. I replaced the sensor and the gauge is at the 12 o'clock position when cold, and the 3 o'clock position when hot. Must be a problem with the gauge itself
81Regal
1,562
486
83
Terril Iowa
Check the ground under the dash on the drivers side. Clean and tighten.
