Temp, oil, voltage gauge not working
86LuxurySport
5
Owasso,ok
I have 86 Monte Carlo luxury sport that the oil pressure, temp, and voltage gauge has stopped working. Everything else on the cluster works. I don't want to go with aftermarket gauges. And ideas would help thank you
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
start the car grab the cluster and wiggle it.
See if the gauges start to work.
Post some pics of the car too!!!!!!!!
86LuxurySport
5
Owasso,ok
Did that they don't seem to want to work.
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
Have you cursed and yelled at it?
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
If the fuse is good I suggest you remove the gauges to check the ground and the connection to the board
pagrunt
9,167
15,342
Elderton, Pa
Here is a odd view of your issue, does the car still computer hooked up/functioning? With the gauges being dead, is the check engine light on? I had an issue like that about around 1995. The fuse kept blowing with the light on. Dealership couldn't find the issue. Another said it was caused by the lock up circuit & told be to unplug it (but I already had a non lock up TH350 in.) I got into things myself & found out it was circuit 39 (guages) that was also tied into the computer. Back tracked, unpluged the computer & fixed the issue.
86LuxurySport
5
Owasso,ok
No the computer has been removed
