Good evening,
I have a 454 BBC in the 1987 Monte SS. I'm attempting to get the gauges working on the dash, but someone hacked the harness and swapped everything to manual gauges before I purchased the car. I'm starting the process of chasing the leads and getting the oil pressure and temp sensor to work again but I wanted to know if anyone has installed a factory style or factory temp and oil sensor in a big block and had it successfully with their gauges. Thank you! Part numbers and links are much appreciated!
Ryan
Ryan
