What’s up guys I’m new to this sit I have a 81 el Camino the temperature light stays on after start up top hose is cold everything else is hot I’m guessing thermostats stuff...
Thermostat I’m assuming is the problemit is probably the sender is defective but you can test that with a multitester if the sender checks out then check the wiring to see if it is grounded anywhere if it is not then it could be a problem with the circuit board when did this problem start did you do any work on the car before this problem started if you did i would go back and check on the work to see if that caused the problem good luck......
I believe it’s stuck closed top hose is cold ever other hose is hotThermostat I’m assuming is the problem
If it's like most cars, the light comes on when you overheat the thing. I've never seen a car throw a temp light when it was warming up, which would be your case if the stat is stuck open.
