I need some help as to which tv bracket to use for my th2004-r transmission with my edelbrock carb and manifold setup for my Pontiac. I have tried 3 so far and none of them work correctly, I tried the stupid universal one but it didn't line up correctly. I am currently using the one from TCI-376700 and the TCI-376710 corrector kit. The problem seems to be the cable is too short, I have it adjusted all the way out and it doesn't want to shift into the next gear unless I release the gas pedal and step on it again, then it goes into 2nd gear. I need someone who has a similar setup like mine to tell me what bracket they are using and what cable. This bracket that I am using now was hitting my manifold so I had to get a 1 inch carb spacer to lift it up to keep it from hitting the manifold. This is very frustrating as there are many different setups and cable lengths from different cars, I am pretty close now I just need the cable to be a little bit longer. The transmission and cable came from a 87 GN any advice would be much appreciated.
