TH200 to TH350 swap
Looter
Jun 27, 2016
74
22
8
so today I finally picked up a TH350 out of a 79 Chevy pickup but I measured and it has a 9” tail shaft and I’ve read that only a 6” tail shaft will bolt straight in. What modifications would I need to make? Shorter driveshaft?
Looter
Jun 27, 2016
74
22
8
I know the TH350 with the 9” shaft is 5/8” longer than a 700-R4 so would I need the driveshaft from a 700R4 G Body?
MrSony
6,793
6,679
Des Moines, Iowa
No gbodies ever came with a 700r4. You'd be better off getting a TH350 with a 6" tailshaft, that's really your only option. Chevy Th350s are literally a dime a dozen. Get one from 1979 and older, so it's not a lockup transmission so you won't have to mess with any wiring. Check the pan and smell the fluid before hand. IF the pan has shavings/paste in it, move on. If the fluid is darker than blood or sparkly or smells burnt (like hair, or burnt toast), move on, etc.
Looter
Jun 27, 2016
74
22
8
What about having a shop shorten the driveshaft?
