TH200 metric transmission been leaking for years just a little leak but I think its from the pump.I hate to change it out because its an all numbers matching 79 Calais,Is a TH350 a direct bolt up to my 305 Chevy?
No. It is also different between a TH250/350C, came out in 80 and the earlier TH250/350.Yes the 350 is a direct bolt up. I forget if my 80 has the 200 or the 250. Is the converter for both of these the same as a 350 converter?
Many thanks I will get those parts checked outMost typical place for a leakis the pan and dipstick tube. Pump seals are pretty durable. Could be output shaft too. They take a lot of abuse. There's no reason not to go th350 but a 3.99 seal isn't a reason to IMO
