th350 to 700r
Doug213xrj
1,529
131
West Michigan
A few years a go I did the same swap, I used the stock G body th350 crossmember. I had to cut a little off the mount where the transmission mounts to the crossmember, Because the mount would hit the 700R4 pan. I also drilled a new hole in the mount after it was cut.
Doug
455'ed80Regal
467
211
Lincoln, MO
Yes, by 3 inches. Driveshaft should be 49.5 inches center to center of the u-joints.
