Can anybody tell me the difference between a th350 floor shifter cable vs a 2004r and why its is important to run the correct cable for the given transmissions.
Yeah I was thinking the same thing and I heard this before thanks that pretty much confirmed itEvan's 85 said:length..you must get the correct one or you won't be able to go into all your gears.
bleedchevy said:Okay now my next question is where can I locate a "floor shift" cable for th350 transmission as everywhere that I looked sombody usually has it confused with the kickdown cable that runs to carburetor or its for 200-4r
Help !!!! :? Up
GhettoRacingKid said:bleedchevy said:Okay now my next question is where can I locate a "floor shift" cable for th350 transmission as everywhere that I looked sombody usually has it confused with the kickdown cable that runs to carburetor or its for 200-4r
Help !!!! :? Up
just the cable? for a stock shifter?
use an older G body to look up the stock cable. my 79 monte came with a 3 spd auto (th200 i believe) and was switched with a th350, both 3 speeds and used the same cable.
