Hi everyone!
Backstory- i have an 86 regal limited. I pulled the drivetrain (307olds, 2004r, 256 non rear) and installed 383, th400, 373 posi.
The trans and motor have a fresh rebuild. Motor so far is running nicely. I finished the brake lines and went to go for the maiden voyage and... i have nothing from the trans.
Fluid is clean and when warm is at the right level. Linkage is correct. Pulled the dust cover to see the flywheel/ torque converter. I can see the output shaft on the trans turning. Its def an internal on the trans. Before i drop the pan is there any parts/ things i should look for? Common problems with the th400?
I had the trans sitting on a shelf for almost a year. It was wrapped- nothing got in it. Its outside of its warranty...
Thank you!
Thank you!
