Yeah, Im kinda surprised that its so low. Its only 510 lift. I know the pump with fix the booster. Just not sure what to do with that modulator. I guess I'll hook up the pump and try it up and down the block. Now Im even wondering if theres enough for the PCV off the carb. Its not looking too good. LOLI heard that the least amount of vacuum is 12". But more is better. You'll probably have early downshifts and late up shifts. Of course, governor controls WOT shifts, so who cares, but the cruising around town? WTF have you only got 9" of vacuum at idle? You got boulders for cam lobes or something?
From what Ive been told vac drops at higher RPMs but Im not sure if thats fact or not. Maybe someone else knows that answer.What is the vacuum with a little bit of throttle where a part throttle upshift would occur? I wonder if the vacuum only sucks at idle?
Timings spot on. Dont know what I could have as a vacuum leak. The lines on the carb are plugged. Only have the single fitting on the manifold. Its a T with a hard line going to the transmission and the other port currently has a barb that I was going to use for the booster if there was enough vacuum. The motors been built for a quite a few years and the only run time was about 30 minutes on a test stand at different RPMs to break it in. Im stumped.Vacuum is like that bad jalepeno- it always comes back. Think of it as a controlled vacuum leak. When driving, the throttle blades are somewhat open as air and fuel are rushing into your combustion chambers as the piston moves down the cylinder (conversely moving air through the PCV system as well). The engine will eat the fuel and air mixture to get to an equillibrium rpm if you hold it in one spot, assuming load doesn't change. Close throttle a bit, you reduce the air/fuel coming in, vacuum goes up, and rpm starts to come down (starving for fuel). Mash the throttle to the floor and you have an instant "hole" basically ruining your vacuum. It's your accelerator pump on the carb, or fuel supply device design based on throttle position that is controlling your fuel and air. If you're system is working right, the hole gets covered up with fuel leading to an instantaneous blast of rpm. If it doesn't, you get the bog, and the car falls on its face.
The 9" at idle tells me something isn't right. A 510 lift cam shouldn't do that unless you're running a 2 cylinder. Timing? Vacuum leak? Bad rings? Something seems odd with that. Obviously I have no idea about the engine, but even my cammed 455 makes around 14 at idle (and shifts fine with the vacuum modulator).
