That was a fun day & 2 out of 3 Hemi's down & one 2015 SS Camaro, three out of 4 for the day. Yes the Hell Cat did go by, my one lose of the day. It's almost impossible to win a race when you're down 300 HP? But had that been a stop light race, I may have won!GoToO it! Nice job spanking newer cars with your 'Honda Accord'. Holden rules!
Greetings Guys; It's been a while since I've posted. Win__r is coming (I don't like to use nasty words) & it's getting cold outside. The weather man is talking 11* tonight. The Bronze Brick has been winterized (their I said it), full tank of Non ethanol premium of course with a 1/4 bottle of Mystery oil. Empty float bowels of fuel including acc pump & replace with a oz of mystery oil in each. Then of course turn engine over for 10 seconds without spark squirting Mystery oil down each barrel venturi. And get it up off the floor, don't want to flat spot those expensive tires. I got a Camaro rear license plate stay down bracket form Slowpoke out of Az & why did I wait 38 years to do this?? Anyway I don't like the fit, even though it has the same mounting holes the angle is different. Also the plate mounting area has a bend that may be original to the Camaro that the Malibu bracket doesn't have. So far I've straightened or flattened it out. Plus it has to be mounted off the Malibu surface some to clear the over center spring area, two nylon spacers from Ace will solve that. Next I will be cutting the spring cover-park position stop area some to get it to set at a similar angle to the OE bracket & hopefully get it to set down on my OE rubber stops. Have any of you guys ever modified any of these before & I just missed where to find the post? Next pull the valve covers & visually check valve train. Will I relax the rockers as I have so many times? I don't know if I'l have the energy to reset them in the spring. Damn ole' body is telling me that's a maybe. And adjusting valves has always been one of my favorite things to do. Yes I'm serious, adjusting valves gives me a sense of accomplishment as the engine usually comes to life soon after. Take Care Ole' Bob.
Ps: Old photo, but I just like to look the rockers & out of OE position valves on the AFR heads. How many of you guys noticed?
I was about to start typing about why the rockers looks twisted, then I see this at the end of your post. Is this an artifact of the AFR castings, or just due to slacking them off?Ps: Old photo, but I just like to look the rockers & out of OE position valves on the AFR heads. How many of you guys noticed?
