BUILD THREAD “The Juggernaut”
Northernregal
Sloppy McRodbender
Oct 24, 2017
3,359
12,826
You can obviously never saw the episode of Engine Masters where they bashed a set of headers near shut and nothing happened.
Dang ol' oldsmabile ain gon' make the horsepowers for that dagone 3" duals anyhow.... (Not spoken with a Canadian accent at all)
king of the hill animation GIF
Rktpwrd
Builder of Cool Shjt
4,155
23,834
Calgary, Alberta, Canada
Rest of the main pipes are finished smoothed out (no pics), then started in on hand filing the flanges flat and true for no leaks.
One down…
…7 more like this one to go.
Also have some copper crush gaskets on the way, and bought some plans for a DIY rotisserie. So we’ll see how that plays out.
Reactions: 14 users
melloelky
4,135
9,484
mass
🔮spoiler alert,he deburr's/polishes the collector gaskets..;)
Reactions: 8 users
Rktpwrd
4,155
23,834
You all laugh, but here’s why hand filing these flanges is worth doing. Observe how just not flat they are. This is why everyone b*tches about them leaking.
After a couple dozen passes with the file:
THESE flanges ain’t gonna leak.
Reactions: 12 users
Rktpwrd
4,155
23,834
Haven’t updated in a while, and don’t really have much to update on even though I’ve been putting in time working on it nearly every night since the last one.
Been mostly just spending time continuing to smooth out the exhaust system, eliminating all the rough grinder marks, pipe seams, and internal weld marks on the sides of the mufflers. The head pipes are finally completely finished, all the flanges have been hand filled flat, and even the edges of the flanges have been polished smooth.
These are all the parts that are completely done and ready for ceramic coat, although I think I’m going to go back and remove the internal weld marks from the bottoms of the mufflers where they’re most visible if anyone cares to look:
I still have the tailpipe pieces left to do, but they still have to be modified to fit better first. I ordered all new 3” copper crush style gaskets for the flange connections, all except for the 3 1/2” collectors. Those I’ll see if I can grab at the local speed shop next week when I’m on holidays.
Mocked most of the system back up on an old blanket on the floor, mostly to take inventory of all the pieces, their orientation, and to make sure I had enough gaskets.
Sure is looking pretty trick!
I “kinda” recall hitting a little bit of a snag with the Doug’s electric cutouts way back when, but had honestly forgotten all about it and what exactly it was. At first glance mocked up on the floor, I figured it was just that they still needed another set of flanges TiG welded on (they’re stainless). But after installing all the pieces onto the car last night, I (re?)discovered that there’s not a snowball’s chance in hell that they’re going to work.
Simply not enough room to the floorboards to fit. So, now I’m on the hunt for a slimmer and more compact set of electric cutouts. SMH, that’s not a cheap proposition. I’ve narrowed it down (about 95% sure) to the Quick Time Performance ones. Most of the reviews are pretty positive on them, they’re slim (approximately 1/2” thick), and should fit in the space I have allowable for them:
They’re special order through Summit, but Amazon has them available for delivery before the middle of September.
Speaking of the cutouts, I mentioned in the last post that I had to “massage” the floor on the driver’s side for the driver’s side cutout flange. “Massage” being via a BFH, sorta. I actually had to cut away part of the main inside floor crossmember to provide room for the pocket I was trying to create, because the area in question was directly underneath the flange of the crossmember.
So how does one go about fixing this little area after hacking it all apart to make room??
Simple, 4 easy steps:
1: Weld up the hole torn in the floor by the stubborn spot weld…
2: Bash the bent flanges of the crossmember back down and form them to the new contour…
3: Make a template of the missing piece of flange…
4: Transfer said template onto matching thickness steel, cut out, shape to fit, and weld in:
If you can’t tell it’s been modified, then I’ve successfully done my job. I really am an animal.
I don’t have any pictures of the underside atm, but this was 100% successful on all accounts. There’s now around a half inch of clearance from the top of the cutout flange to the underside of the floor in this area. As for the topside, this area is underneath the seat so it’ll never be seen.
I tried bolting up the unmodified tailpipes to the rest of the system last night, but that was absolutely no bueno. They definitely need to be tweaked, changed and re-clocked. However I think I can change the bends to make an even better approach angle and alignment to the pass-throughs. But before that can begin, first I have to come up with a pipe hanger design and way of supporting the back of the system before the tailpipes. This will lock in the height of the backs of the mufflers so I have fixed points to work from.
And the geometry corrected modification and re-welding from last time? 100% successful as of last nights’ first test fit. All my clearances are back to where they were and should be. Win-win there.
All for now, thanks for continuing to follow along gents.
D.
  • In Love
Reactions: 18 users
clean8485
2,860
2,136
Ontario, Canada
Awesome work as always Donovan. Have you run the car with the Flowmasters in the past? I'm just wondering what you think about the sound level from them.
Rktpwrd
4,155
23,834
I have run Flowmasters in the past Jeff, in fact they’re my preferred go-to brand for that deep throaty muscular sound I love. Just not this particular series. These are the Super 44’s, supposedly Flowmaster’s most aggressive sounding muffler. This thing is definitely going to command some attention when running if that’s the case.
I’ve run Super 50’s and the Delta style Super 40’s on this same 455 in this exact car before, so I like to think I have a pretty good idea of what to expect. I know lots of people don’t like Flowmasters, but to each their own. I for one like ‘em.
Man, you're not only good with the welder but also the grinder! Have I got some (no paying) work for you! :ROFLMAO:
Haha, everyone has some form of no paying work for me, just ask my dad with his current motorcycle project.
All joking aside, proper grinding really is as important as the welding (if that’s the desired effect you’re going for) and it was definitely a skill I’ve worked hard to try and improve and master.
It’s still an ongoing endeavour.
Thanks for the compliment!
Streetbu
Know it all, that doesn't
3,721
11,525
Central NY
If there's one thing I've learned about grinding, a deft touch goes a long ways. I was always like a bull I'm a China shop with a grinder. After having to polish out stainless steel welds at work, there is absolutely a method to it. If you go heavy with the grinder, you pay for it...
Looking good Donovan!
