The night the lights went out on my cutlass ha
Heather b
7
2
Hi all! New to the group as I just got this 84 cutlass supreme last weekend. Finally got her tagged yesterday and weather was nice so decided to take her out for a stroll. Everything was going great until I stopped to get the kid. Turned the lights off, turned the car off, 10 mins later, no headlights, no brights! Taillights are good, dash lights good and the little blue brights indicator was illuminated on the dash, blinkers worked….. anyone run into this? Any ideas of where a gal might wanna look first. Seems unlikely that allll my headlights died at the exact same time. Appreciate anyones ideas or tips as I get going on showing this gal some love!
Heather b
7
2
Headlight switch. .....BEAUTIFUL car !!
Thank you. I'm waiting on one now. Went ahead and ordered that and new headlights, figured I might as well. Does that going bad cause the bright light indicator to illuminate on dash when the you try to turn the lights on? I just thought that was super weird but this is also my first car like this sooooo I didn't know. Thank you again.
Heather b
7
2
Nice looking cutlass welcome aboard, check all the fuses and any loose wires under the hood around the lights
Thank you. I did check the fuses and then checked the wiring today when I was cleaning leaves and such out. All looked good there. Of course this would happen when I get her and gets dark the same time I get off work so now I can't drive her as much as I'd like. lol
Drkuhar
512
912
Girard, IL
When mine did that it was the dimmer switch on the column not the headlight switch. The blue on the dash would be on with no lights and if i clicked the dimmer a few times the lights would come on and then go back off. The indicator was working like it was supposed to, just no lights
SS_Malibu
1,164
2,034
Mesa, AZ
Welcome to GBodyForum! Nice Cutlass. It looks as though you have already addressed the lights issue. And on an unrelated note, It's nice to see GBody Girls here as well, Heather. Most people seem to forget the car culture does not care who you are. Age, Sex, Religion, Race; we are a family bound together by are pure interest in keeping our automotive passion alive. Again, Welcome Aboard.
PVDave
Oct 28, 2021
52
34
Arvada, CO
Taillights are good- Tail lights use the headlight switch but have a different fuse and circuit than the headlights. Not the issue
Dash lights good- Dash lights use the headlight switch but have a different fuse and circuit than the headlights. Not the issue
Blinkers worked- Blinker circuit shares no components with the headlight circuit. Not the issue
The little blue bright indicator was illuminated on the dash. Now we're talking-
Turning on the headlight switch sends power to the beam select switch (high beam switch).
From there, the high beam switch either powers the low beams or the high beams at the front of the car.
Also, when the high beams have power, the blue bright indicator has power.
Since the indicator turned on, It appears the fuse, headlight switch and high beam switches all work.
Since all four headlights were out, I'd suspect a problem with the headlight grounds (the blue indicator turns on because the gauge cluster uses a different ground).
The headlight bulbs could be bad as well, but as you said, that's pretty unlikely.
