MONTE CARLO The notorious J-tool conspiracy
CopperNick
3,357
3,018
Canada
For those who took the time to follow my adventures in power steering land, where we left off was with me finally getting the return line fitting and adaptor installed and nailed down and a new rubber line cut and installed to complete the circuit.
Which brings me to my latest question: Has anyone on the board ever heard of a GM made, "J" prefix tool that was specifically created to tension the power steering pump belt? Yeah, I know, big screwdriver and push on the pump body while frantically trying to reach the bolt that comes into the bracket from the header side of things and tighten it up. I have two pumps sitting on the lid of the trash can that had that type of tender ministration paid to them and have the dented body to show for it. Not looking to revisit that modification with my latest pump body which is in fairly decent shape and freshly painted. Am I going to have to argue with E-Bay about this??
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
JC Whitney used to sell a tool that had two curved plates and a turnbuckle. Slip it between two pulleys and turn the coupler until you got the right tension. then tighten down all the adjustment bolts.
CopperNick
3,357
3,018
Canada
Sweet!! Just off the top of my head I think that I might have all the raw materials, including a turnbuckle, to gin together a home brew version of what you just described.
Thanks large for the inspiration!
jiho
1,001
508
What I use. Those curved plates are a bit flimsy, and it's easy to muck them up, so you do want to be careful keeping things lined up. But it works, and sure saves a ton of trouble. Takes a 3/4" wrench.
EDIT: Seems "used to sell" is right. I was just there and could not find it. Glad I got my second one before they stopped carrying it.
565bbchevy
9,614
12,683
Michigan
I just use the P-tool method
Reactions: 4 users
jiho
1,001
508
Isn't there a square hole for a 1/2" drive breaker bar? I was out there earlier today, and I'm too lazy to go back.
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
  • Winner
Reactions: 4 users
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
Yep. On a serpentine setup. This allows you to pull back the tensioner. The tool we're chasing is for V-belts.
jiho
1,001
508
No, I mean on the PS bracket itself.
Ribbedroof
4,900
6,991
Wellston, OK
On mine, you need to pull the pump up. I use a short prybar under the bracket with a short length of lumber as a fulcrum between the box or frame and pump bracket.
According to the 1983 Caballero svc manual (which is just the Chevrolet carline manual with a Caballero cover), some models/engines have a square drive in bracket, others do not. For those, that require the pump be moved out, this drawing is provided
There IS a J-tool for measuring belt tension.
