The Official Component Weight Thread!!!
Sep 1, 2006
6,687
33
Tampa Bay Area
This thread is for posting the weight of various stock or aftermarket parts and components of your G body for the knowledge of all. It need not be a stock part, but be sure to put down the model of car, component, year, and engine (where applicable). For example, don't just say Iron SBC head, say Iron World Products head for SBC, etc. Anyhow, I will get the ball rolling with a few components I have weighed. I will be adding more, such as the Aluminum hood in the future. Please though, someone post the weight of the steel hood, bumpers, etc. ( Please make this a Sticky!!!)
Dash for Cutlass with no switches, gauges, radio or wiring: 23.6 lbs
R-4 A/C compressor with clutch: 17lbs
Weld Draglite wheel, 15x8.5: 14.8 lbs
Global West Upper front Control Arm: Just under 10 lbs ea.
Cutlass Supreme Brougham 60/40 split front seat, driver's side with power: 55.8lbs
1992-95 Honda Civic 2 door driver's seat with tracks: 33.2 lbs
Steel 85 Cutlass 2 door front fender stripped to bare steel: 11.6lbs
Plastic/aluminum Modine replacement radiator for 3rd gen V8 F car: 9.4 lbs
Power steering gear box, 1984 Monte SS quick ratio: 28.4lbs
Door Glass, 86 Monte Carlo: 15.8 lbs
T-5 manual transmission from V6 4th gen F body: 82lbs
Aluminum hood, with hinges and no springs: 25.4lbs
Fender with 2 paint jobs, Bondo, and primer surfacer: 12.4 lbs
Copper-Brass radiator from a 1972 AMC Hornet: 18lbs
(Please someone post a G body Copper-Brass 3 core)
Another area of weight savings most of us do not think about is the battery. I weighed a 35 series battery and got 38.8 lbs. I wonder what the small battery used in a Civic would weigh?
Complete cruise control system from 86 Monte Carlo: too light for my bathroom scale to measure.
Now, get out your bathroom scale and start weighing stuff!
Sep 1, 2006
6,687
33
Tampa Bay Area
The Junkyard. I found it by accident. It is super-hard to find one, but you may get lucky if you search for one. Mine was on an oddball car in that it was a Cutlass Salon with T tops and a diesel engine. You can also get bumpers with aluminum supports instead of steel, and they are far more common.
Anyhow, here's another addition:
Door Glass, 2 door (Monte Carlo): 15.8 lbs per side
shotgun
1,067
80
48
Nort o Philly
HFX
May 13, 2008
96
Atlanta, GA
That would require me removing mine. Not happening right now buddy. You can get an after market aluminum one pretty easily that will replace it. However, expect to have to make shims to make them fit properly.
I'll check when I get home if I still have the shipping invoice which may have the weight on it.
Coveted
624
Sanborn, Ny 14132
I can way my front bumper with aluminum support, and potentially my hood today/tomarrow
I already ditched all the stuff I stripped off the car or id be able to weigh more stuff.
Sep 1, 2006
6,687
33
Tampa Bay Area
It would require me removing mine as well. I am not asking anyone to take their car apart, only for those of us who have our cars torn down to take a few minutes and weigh some of the components we already have removed.
dougfather
286
5
16
Altoona PA
I made this a sticky. I combined a few posts into one. More to come.
Sep 1, 2006
6,687
33
Tampa Bay Area
Weighed another thing tonight:
1996 Honda Civic battery: 28 lbs.-- A savings of 10.8 lbs over the stock one in my G body. It is a top post, so you would need the adapters to make it work.
Sep 1, 2006
6,687
33
Tampa Bay Area
Stock steel hood from a 1979 AMC Spirit ( slightly smaller than a G body hood) 41lbs.
speaker box with two 10 in subs: 36lbs
GM direct drive starter motor with solenoid: 14lbs
15x7 steel wheel with 225 70 R15 tire: 54lbs ea.
16x8 aluminum Enkei 92 wheel with 225 60 16: 41.8lbs
