MALIBU The Sunken Ship Build Thread!
10,540
14,217
What I do on boats is to run right off the battery to one of these waterproof breakers. Then on to a breaker panel for all the electrical needs. But on our cars I think just one breaker right off the battery could feed the entire car just like the stock fusible link. I use Blue Seas and they have been very dependable.
mclellan83
4,204
9,310
Pgh, PA
Man you are a gluten for punishment, but awesome of you to step up and help a buddy out
7,981
18,676
fleming442 Bruce, you in the house?
Yah, mon. Y'all are on the right track. Those fusible linked 10 gauges at the starter and alternator can absolutely be consolidated somewhere other than the starter. I've been looking for a multiple, MAXI fuse distribution block for a while, and haven't seen one. You could probably slide with 30a ATCs, but I'd feel more comfortable with 40-50a since they feed the ignition switch.
You can also run an upsized charge lead directly from the alternator to the battry.
9,127
15,257
Would this set up work for you?
The fuse block is from a late '80's/early '90's H-body Olds 88, cable is from a '96-'98 C/K, the bag of terminals was scored from a Chevy stealership.
Ribbedroof
4,865
6,892
Wellston, OK
On my coupe and wagon I extended the 2 feed wires and the start wire, mounted a remote solenoid on the inside of the fender, and haven't had any issues since. I also like that the starter cable is only hot when cranking, not all the time under the car
LT1B-Body
183
86
Maricopa Arizona
I stripped the interior out to keep it from being ruined by the rain, since there is no windows in the car.
Found some rust and holes in the floors unfortunately
  • Wow
  • Sad
