As the subject line says. I am contemplating this swap. My car/truck search turned up only a few prospects, including the El Camino. I have to go back to the dealership and see if they're selling it. It's stuffed in the back of the building with some other cars that I guess are not sell-able. Hopefully it's not somebody's project.
If I am to get this, I will do the LS1 swap as it would better suite a daily driver than whatever is in there (carb'd 231V6 or the 305sbc). I know about BRP and even though the pricing is up there, I might use them for mounts and headers. I read the LSX swap thread and have a few questions.
I would like to retain the EFI. I remember finding a company called Street & Performance (or something to that tune) that made engine harnesses for these swaps. I looked them up several years ago when I still had my Malibu. I think Painless makes harnesses too. Are there any other companies that make engine harnesses work for these swaps? Gauges; I imagine I would need to use something different in place of the mechanical (dummy lights) gauges?
I am really sold on using a T-56 trans. I think the Mcan I stick PG should be a little better than an automatic with OD (4L60E?) Plus, it would be more fun to drive that way. How much cutting is required to fit a T-56 behind a 6.0L in a G-Body? What have you LSX swap guys done with the driveshafts? Do they need to be cut? Also, does Honest Charley's (or Choo Choo Customs) still sell the stock G-Body clutch pedals and linkage? I know I will have to go hydraulic for the setup, but they do have the pedals at least (I think).
Fuel pump. Does anybody run an in-tank fuel pump or do you use an inline like a Aeromotive A1000?
Then there's the rear differential. I imagine I will have to swap that out at some point. Unless I got the same rear ratio that I had in the Malibu (2.41 ), can I stick with something like a 3.08 or whatever the Elky's come with? I know there is an aftermarket drivetrain offerings for these cars/trucks, but for now I will stick with what I got until I get the time and $$$ to swap it out.
I apologize for all of the questions. I just want to try and cover all bases before I get the ball rolling (if it does). Thank you for any help/advice that you can give me
I will probably post more ???? as I think about it a little more.
Chickenbone
Chickenbone
