So my little 260hp 350 ate the thrust bearing and pumped all that bearing material through the engine. Its the standard 4 bolt main 2 pc rms block from GM. It is looking like it will need at minimum a new crank and a hone job on the cylinders or possibly an overbore. lets assume it is going to need the overbore I might as well stroke it out to a 383. Or do I just take the simple route and buy this Blueprint 383 short block with 1pc rms and roller cam with all forged internals? Blueprint 383 BP38321SP
If I go with the BP383 I will be topping it with a set of ported 441 iron heads that would drop the compression down to about 8.7:1. My concern is that the cam in this short block would be just a tad too large (Cam Type: Roller, Lift with 1.6 rockers .528 Intake .536 Exhaust, 221 Intake / 226 Exhaust duration @ .050 - 110 degree lobe separation). I would probably use 1.5 rockers to help pass smog and tame the cam for lower compression.
Here is where I need your help, I live in the "wonderful" state of California and still have to smog the car. Obviously I can keep a straight face at the smog station and say its just a measly 350. What would you do if you were in my shoes?
Long term plans will be to grab a set of AFR's in the next year or two to bump the compression back up and really like this thing sing. Car is mostly used on the street 95% of the time with the once a year trip to the drag strip just for fun. Budget is as cheap as possible - $5,000. Current setup- trans is a performance automatic TH350 rated to 550hp, 8.5" rear with 4.10's
I appreciate all the feedback possible.
