Friends, I have adjustable upper and lower trailing arms on my 1985 Cutty. I had the front end aligned last month and was dead on straight, steering wheel and all. In detailing the car for a show this weekend, I noticed that my rear end was about a half inch further right (to the passenger side) so I adjusted my uppers and got it measured back to dead center. Took the car out and sure enough when the car tracks straight, now the steering wheel is slightly turned to the right. I know this is due to the thrust angle of the rear end now being different then when the car was aligned. Im trying to understand the physics of why its straight but the wheel is now slightly right. Does it means that based on current front end alignment the axle is now to far forward on the drivers side?So should I....
A: Quit being OCD and not worry about it.
B: Get the front end realigned
C: Play with uppers and lowers to see of i can get it back straight.
Is there a way I can tell if the axle is straight? Measuring from tire to fender well the drivers side is a lil bit more forward...but I know that is not a good acurate measurement due to too many variables. Again I only adjusted the uppers...not the lowers at all.
Any help is appreciated!
