timing for Olds 455
scarborough
306
66
What's a good timing setting for a Olds 455 with Edelbrock cam it has Hei distributor with stock plugs, in process of changing the plugs to Ac Delco r46sx. my mechanic has the timing set at 20 degrees. just wonder is that's good.
also what brand oil filter are you guys using I like Ac Delco for my chevy motor. not finding a good Ac part number for the Olds.
Oct 14, 2008
8,818
7,763
Melville,Saskatchewan
Wix 51258 or Hastings LF222. You need to see what curve is in that distributor. Some have similar to a sbc or Olds points curve. Some have 14 to 16 mechanical advance built in. Get a dial back timing light, set the total around 34 to 38.
pontiac guy
582
843
Royse City, TX
How much total timing does it have? How does it start hot?
Rt Jam
591
580
Ontario Canada
A fully tuned distributor will have at LEAST 3 things. Timing during cranking, idle, low load cruising and max power.
When is your engine at 20? With no vacuum advance during idle? If so, that's a tiny bit high but if the spread in the mechanical system is say 20, then you will have 40 at high rpm. Too high.
Oct 14, 2008
8,818
7,763
What is your compression ratio?
