I have a 30 over 350 flat tops 041 GM heads big valves with port work. I am around 10 to 1 compression with 1.5 roller rockers. I am running an comp magnum 292 h cam. When I swapped motor over I changed from vac advance to a summit mech advance distributor. Where should I be with this setup? I have 3000 stall and 3.73 rear.
https://www.jegs.com/i/COMP-Cams/249/12-213-3/10002/-1
