Tire size question
LeftLaneOnly
293
486
1979 Cutlass H/O
I have BF Goodrich AT's on it now 245/60/14's
I want a less aggressive tire/tread as it is only a fair weather driver. Should I look for a 245/60/14 size replacement I like to look of the 60's and may go thinner in the front.
Your Thought's
lilbowtie
3,460
3,965
Canton Mi
Have you thought about going to a 15in rim and opening your tire availability? If you stay with 14's a 70 series would fill the wheel well more - 2 inches bigger than 60's
clean8485
2,860
2,135
Ontario, Canada
As stated above, going to a 15" rim would increase your choice of tire sizes, and give you a better chance of "filling" up the wheelwells. I know that the 14" Hurst/442 rims are kind of unique, and that particular style of rim only came as a 14" rim, but it does limit your choice of tire size.
Kratos
200
316
Central Pa
I have a couple sets of 15" Ralleys in Central PA if you are interested. you could run 235-60-15s all the way around with them
LeftLaneOnly
293
486
I do not plan to change the rims I would like to keep the width of the tires in the back and maybe something a little thinner in the front the height of the tire is fine.
black wall..white wall raised white letter undecided
Kratos
200
316
Central Pa
your tires are 25.57" tall, to keep that height, but be thinner would be tough! 205-70-14 is a little shorter, 205-75-14 is a little taller G ( or A body) cars are pretty good up to about 26.3 in the front and 28" in the rear without fitment issues
McGillicutty
169
240
Oshawa, Ontario
I have 235/60R14 front 245/60R14 rear installed by PO. Not much visual difference between 235 and 245. They both have a lot of rubber squishing out on either side of the 6 inch wide rims. But if I ever pick up a nail, I will go narrower all around. 1) Limited rubber for 14 inch rims and 2) the squashed sidewalls make me uneasy about unusual stresses in the tires.
Macguyver
SOUTHSIDE MACHINE PERFORMANCE
GBodyForum Sponsor
Mar 21, 2017
292
458
If it is a stock 14x6 do not go 245. If you want sidewall try 205 - 225 in a 70 or 75 profile.
Oct 14, 2008
8,806
7,746
Melville,Saskatchewan
Consider a 205/70R14 or 215/70R14 in a Cooper Cobra, a bit more modern tread than the BFG TA's. I have 205/70R14 front and 225/70R14 in BFG TA's on my factory 88 aluminum wheels, looks good.
79 USA 1
1,062
2,033
Cheektowaga, New York
I've ran both a 245-60 and a 215-70 on my Monte Carlo Checkerboards. Main benefit of the 215-70 was at the time finding it in a Michelin brand (Sears Roadhandler) and a thin white stripe.
The Checkerboards are a 14 x 6.5 wheel
215-70R-14
245-60R-14
