Tire size
eugrides
34
What is the maximun size 17 in tire on 8 in rims I can use on my 85 monte carlo I want a high profile tire that won rub. I am interested in a smooth ride I have 245/45/17 on it now and don't like the ride. the suspension is stock
Streetbu
Know it all, that doesn't
3,733
11,573
Central NY
You can't fit a taller tire than what you have. You need more sidewall for a plusher ride, drop down to a 16" or a 15"...
eugrides
34
If I go with 15 in rims I know the stock size was 215/65/15 with 7 in rims what larger size can I put or rear and do I need a larger rim
9,611
12,670
Monte's have a pretty generous wheel well and it is round so I don't see why you can't go taller
Just for comparison a BFG 245/45R17 on a 8" rim has a height of 25.6" the factory 215/65R15 is 26".
I have 28" tall rear and 27.5" fronts on a lowered Monte with no issues.
10,563
14,293
I ran 225-75-15 tires on my wagons. Pretty cushy ride. The problems were with the front wheels rubbing now and then. But I did not science out the wheel offset and back spacing. I just used what I had.
10,563
14,293
Now that I think about it that was with American Racing 15" wheels. Unsure what the offset was and I got light rub up front on severe turns. I also used stock Pontiac Firebird Rally II 15" wheels and nothing rubbed at all with those tires. Perhaps stock Monte alloy wheels would be right?
eugrides
34
Can I use 215 /70./15 on front and 225/70/15 on rear with rally wheels with a 4 1/4 back space
