Tires for Rally Wheels
timandsam
7
Hamburg, PA
Hi All,
The tires on my 87 Cutlass are all dry rotted and I am looking to replace them with something a bit bigger. Currently they are 195/75/14. I am running 14" Rally wheels. I want the same size tire all the way around for ease of rotating tires. I know this has been asked a thousand times and I did search but did not find anything conclusive.
So my question is, can I run 225/70/14 tires? Or is there a better size to use on these stock 14" Rally wheels that I can run on the front and rear?
Thanks,
Tim
paul.m
404
201
Not sure on 14,s but on 15,s 215 on front is supposedly the largest front tire without scrubbing on stock suspension . I can tell you that 235,s on 15,s do not work well , i have seen 285,s 15,s on rear and seem to work.
pagrunt
9,167
15,342
Elderton, Pa
235/60/14 would be a good choice if you can find them. 14" "performance/sport" tires are getting hard to find. Might be worth the hassle to find 15" rally's if you want to keep the stock look. Then you'd have a slightly better choice. Stock 15" tires were 215/65/15 (MCSS, 442, GN). A 235/60/15 fits all four corners with no issues, what I've been running over 20 years. A key measurement to keep in mind is how tall of a tire to use, all stock 14" & 15" tires were 26" tall.
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
I ran 235/60-15 no problem on all four corners using a set of S10 steel rally rims that had they same zero offset as the stock 14s. The widest I'd suggest for 14s is a 225/60, which might rub on the fender liners in the front.
paul.m
404
201
For some reason that,s where mine rub on 15,s , the inner fender . But only during hard bump,s and really tight turn,s
Gonzo1970
898
1,302
Ive got 14" Rally II's on my GP. Your Cutty may differ, but I don't think they do...
Right now, I've got 225/70-14 Rear, 235/60-14 Front - about a 1.3" Stance. While I don't mind the stance, and the meat up front, they're date-coded 1994 and the 235/60-14's on the front now, rub at full turn. :(
I am going with 225/70-14 on the back - 205/70-14 on the front.. Thats what I'm doing on my GP. Give it about a 1" Stance.
As far as all the same size, if you held me down and made me do it, I would go with 205/70's but really, rotating only really needs to go Left-Right, so switching L/R Front and L/R Rear is perfectly fine in my book.
-Gonz
Jeff Blagden
453
654
Winnipeg Manitoba Canada
I run 14 inch 225 /70's om my 1980 442 they rub the inner fender well just at the end of a full turn when backing out of a tight space but 98% of the time all good have a good day and good luck Jeff from Winnipeg
DoubleV
2,154
406
83
Medina Ohio
215/70/14 Cooper Cobras. Same general height as your stockers. Here's what they look like on my car.
