So I typically always buy a battery that has both top post and side post terminals.
Question, can you hook up to both terminals at the same time?
For instance, I have my 1/0 gauge power wire, 4ga stereo amp wire and 8ga electric fan wire coming off the top post of the battery. I am running a 4 ga positive wire from the alternator to the battery. Can I hook that to the positive side post terminal? Or will that only screw something up on the battery?
I bought just bought a replacement 4ga starter wire for a 307 Cutlass that already has the side post terminal on the end. I was going to cut the other end off and trim it to the length I need and then just connect that to my alternator. Cheaper and easier than find 4ga power wire around here.
Thanks,
Thanks,
