Hello everybody.
I bought 1984 Cutlass supreme without an engine ECM harness.
I'm in the middle of 5.7 TPI Speed density swap and I'm trying to figure out some pinouts.
The connector is on the passenger side where ECU was.
I need
12V (always hot)
Ignition switched on
Check engine light
Break pedal switch for lockup
A/c on
But best if someone could name them all.
Thank a Lot
One side is:
A) brown wire
B) orange wire
c) white/green wire
D) - (empty pin)
E) white black
F) pink/black wire
G) - (empty pin)
H) light brown/black wire
Another side:
J) - (empty pin)
K) brown wire
L) - (empty pin)
M) black/white wire
N) orange/ black wire
P) purple wire
R) - (empty pin)
I need
12V (always hot)
Check engine light
A/c on
Thank a Lot
One side is:
A) brown wire
B) orange wire
c) white/green wire
D) - (empty pin)
E) white black
F) pink/black wire
G) - (empty pin)
Another side:
J) - (empty pin)
K) brown wire
L) - (empty pin)
M) black/white wire
P) purple wire
R) - (empty pin)
