Trailing arms???'s
dickeymoore
924
Atlanta,Georgia
I'm looking for some good budget lower trailing arms for my daily driver G-Body I'm thinking like UMI performance or Summit Racing which ones are good ones or does anyone have any good used ones laying around for sale
Macguyver
SOUTHSIDE MACHINE PERFORMANCE
GBodyForum Sponsor
Mar 21, 2017
292
458
dickeymoore
924
Atlanta,Georgia
Do you have any G-Body trailing arms that recommend for a street car daily driver I see you make the ones from Summit Racing and I might can get those on a cheap
Gwarren79
711
1,547
Safford, AZ
Speedway motors - 119.99
Macguyver
GBodyForum Sponsor
Mar 21, 2017
292
458
Macguyver
GBodyForum Sponsor
Mar 21, 2017
292
458
Any particular reason to change from stock??
Southside Machine Rear Lower Control Arms are one of the most important suspension modifications that can be done to your GM vehicle. Stock control arms are on the borderline of junk, bushing deflection and rusting weak stamped material add for traction loss and poor handling ability. Our tubular control arms are designed to give you the best of both worlds, whether your car is a weekend cruiser or a weekend track addict we got you covered. These control arms are a direct bolt-on replacement designed to minimize wheel hop, improve corning and help track consistency. Lower control arms are supplied with sway bar mounting holes designed for your stock sway bar and most aftermarket bars. Poly bushings and fully boxed and welded built to handle the most severe abuse you can throw at them.
These are truly overkill! All grade 8 hardware is included. Made in USA!
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
the lowers are good but I would not use those uppers without a spherical joint to allow the uppers to twist to prevent the suspension to bind
lilbowtie
3,460
3,965
Canton Mi
I was only asking are individual why the change. Rust is one thing, and bushings can be changed and they can be boxed. I will use your quote for changing - " These are truly overkill"
  • Winner
