I was told that the axles used in the '79-'81 Trans Am disc brake rear were different than the same year drum brake rears. Yes? No? I ask because I have some disc brake parts that I could either use on another leaf spring rear or a G-body rear. If the axles are the same it is a no-brainer swap and I can build another F-body disc rear. If not, then I was figuring to drill the G-body axle for the four bolt rotor brackets like they do for the four bolt bearing retainer kits. The two bottom bolts should line up and then mount the rotor brackets after drilling the top two holes. Since the G-body drum axles locate the drum almost exactly like the F-body I figured they would interchange. I am relying in GM cheapness here thinking they would not make different axles, just adapt the rotor brackets to fit. That way the disc parts would swap over.
