Trans. Crossmember Bushings
Opie Knievel
Rum Fueled Midnight Mechanic and Moderator
Sep 6, 2010
1,512
1,859
Brodhead, Kentucky
I'm finally doing the transmission rebuild on the TH350 in my Monte Carlo. While removing the transmission I found out that the bushings that hold the crossmember to the frame are shot. I've been looking online for a replacement set and I found some but they're a little expensive.
These are the ones I found.
This is where I found them. http://www.buickgn.com/crossmembermounts.htm
Does anybody know where to find them cheaper?
Texas82GP
Just-a-worm
Apr 3, 2015
7,981
18,676
Spring, Texas
Those are the ones I bought. They were the only ones I found. I like that they are polyurethane. Let me check my OPG catalog. You might check with Mikes Montes. Many have said he has way more stuff than is on his site.
Texas82GP
Just-a-worm
Apr 3, 2015
7,981
18,676
Spring, Texas
Nothing in all 3 of my OPG catalogs.
axisg
2,685
2,354
YYZ
Odd, I don't recall those bushing on any Gbody I have ever worked on. 99% sure the only bushing I have is on the trans mount.
Texas82GP
Just-a-worm
Apr 3, 2015
7,981
18,676
Spring, Texas
I didn't find them on The Parts Place website either.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
I don't see any need for them. The support bushing installed on the transmission isolates the transmission from the crossmember, If there are any vibrations transfered from the tansmission the crossmember which is mount directly on the frame the body mounts isolate the body from the frame
Opie Knievel
Sep 6, 2010
1,512
1,859
Brodhead, Kentucky
Ok. Then how do I attach my crossmember? The bolts go through the crossmember and into the metal part of the bushing. That's where the threads are. How else would I go about this?
Texas82GP
Just-a-worm
Apr 3, 2015
7,981
18,676
Spring, Texas
What about the change in driveline angle from eliminating them?
