Trans Crossmember rubber mounts
Trader history (0)
CrammerGram69
334
SW, Michigan
Hi im looking for nos or very good condition used of these for my transmission crossmember in my 1979 Pontiac LeMans car. Originally a th200 now a th350. (Bop). Or at least the gm part #. 20220723_211714.jpg
Any help or photos showing how they mounted. Thanks.
78Regal350
Apr 13, 2015
77
33
Brookville, IN
The insulator retainer, insulator, & mounting bolt are part 2, 3, & 6, respectively, in the link below. In addition to p/n 459092, you can search part #s 472165, 457908, & 457909 for the insulator. Note you'll need (2) retainers, (4) rubber insulators, & (4) mounting bolts. As far as mounting is concerned (and if the illustration in the link isn't quite clear), each end of the trans. crossmember gets sandwiched between rubber insulators, with the retainer mounted on top & the bolts run up from the bottom.
FYI, when I was looking for a NOS set of these I checked all the "NOS parts websites" to no avail, but ended up finding a full set on eBay for $100.
  • Informative
CrammerGram69
Thread starter
Nov 15, 2019
334
SW, Michigan
Thank you! Very helpful and informative. The pictures i posted is what I have currently. Does it look complete? I will look at the Illustration. 🙏🏻
