Trans go shift kit tv boost valve stuck
442_87
Jul 19, 2014
70
8
Hello Everyone,
I was installing my transgo shift kit, and I have concern / question on the tv boost valve ( for the pressure regulator)
So the factory one was a pain to get out ( no idea why)
So I put in the new one as per trans go instructions.
It went in real stiff( this should of been a sign to stop) but I didn’t
I tapped it in, set the snap ring . When I push on the valve with a screwdriver it barely moves .
Anyone out there can help?
Now if it is an issue , how the heck do I pull it out( transmission is still in the car )
Thanks in advance
442_87
Jul 19, 2014
70
8
Hello Everyone,
Thanks in advance
Anyone?
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
Have you tried calling their Product and Tech Support (626)-443-7451
8,806
7,746
Melville,Saskatchewan
It doesn't move a lot, I have done a few of these kits. I had one where I didn't get the snap ring in right and it shot into the pan going down the road. With the snap ring removed, a light tap should loosen it to remove.
442_87
Jul 19, 2014
70
8
Hello Everyone
An update i just got off the phone with Tech support, and he did mention that it shouldn’t be stiff going in perhaps it was a burr ? Mind you I didn’t feel one .
. He did mention the movement is minimal as noted by "olds307 and 403" the movement is minimal ( About 37 thou ( approx a mm , i'm metric guy) )
Thank you to PontiacGP and Olds307and 403 for your responses
Much appreciated , will post an update once i'm done.
Thanks
442_87
Jul 19, 2014
70
8
Ok update
Well I manages to put it back together triple checked the check balls , and everything else
So filled it with 6 liters then started and added 2 more liters
Took it for a drive, seems ok then it stopped shifting wouldn’t catch second gear. Stuck in first no matter I did . I tried manual shifting it , but no luck
So I took the pan off again , and the fluid was dark and smelt as it was burning
Any ideas? Looks like I may need a transmission?
Any help would be greatly appreciated
Thanks
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
That sucks, I hope someone jumps in to help you out. I don't have much knowledge of auto transmissions...
8,806
7,746
Make sure the governor is all together, it will not shift past first otherwise. Did you check line pressure?
