trans oil cooler line size?
oldsmobile joe
2,067
3,053
mpls
so my question pertains to the steel lines that run between the trans and oil cooler. our cars came with 5/16" lines and are attached with brass adapters that have a 1/4" opening.
newer gm vehicles, 94-96 caprice for example, have 3/8" cooler lines, but are still attached with brass adapters that have a 1/4" opening.
so what are the advantages of a larger, higher flowing cooler line if they still go through the same 1/4" opening at the trans? i feel like I'm missing something, this doesn't seem logical.
Tony1968
2,319
5,112
NW Indiana
Yes that doesn't make sense. But I'm sure you can change the fitting at the trans to allow the larger size all the way to your cooler. for instance I have 6an fittings on trans and same lines which are 3/8 of an inch
