Trans swap help?
84supreme
13
I have a turbo 350 trans in my 84 cutlass supreme 307. I have a r700 i want to put in it. I was wondering what all i would have to change to put the r700 in my car, will i need a different driveshaft? will it just bolt right in? Thanks!
I don't think the 700r will bolt up to the 307. I believe the 700r has a chevy bolt pattern and the 307 uses a BOP pattern. I might be wrong though.
ok so any trans from a chevy wont fit on my car? Because i can aslso get my hands on a rebuilt th350 with a shift kit.
i thought they made something like an adapter plate thing for that though? only trans with the universal bell housing that i know of is the 200r4 other than that chevys differnt than olds, you got your chevy bellhousings and then your BPO bellhousings, (buick pontiac oldsmobile)y your gonna have to find a trans with a BPO bellhousing
you can try and i mean try to get your hands on a universal 200r4 IF you can find one
best way to tell the diff between a BOP and a chevy trans is BOP has a half circle design while the chevy has a triangle look
the universals with have ALOT of holes around the bellhousing
i have a 200r4 sitting in my garage with the universal bell housing(junk internals tho), i have gone threw about 6 200r4s in my life, and all were universal bell housing, i didnt think they were rare? i may be wrong and just got lucky haha are they rare?
You can use the TH350, as long as its the BOP type.
"IF you can find one"?????
You'd be hard pressed to find one that ISN'T dual bolt pattern. I've seen pictures of one of the very early BOP-only 200-4R transmissions, and I've heard rumors of (but never seen) a Chevy-only version, but 99% of all 200-4R cases are dual bolt pattern.
