Trim rings on SS III wheels???
DROLDS84
464
788
Northern Indiana
I believe he means these....I have seen trim rings on them before but not sure what rings were from.
8,195
17,595
Here's a 442 wheel which matches the above pic. IIRC, the ONLY difference between the 14" and 15" wheel was the width of the band where the valve stem goes which made the 1" difference. And the width, obviously. But the shape didn't change, and they both used the same center sections.
I believe the painted 15" units used the same rim, just not chromed.
And a 14 x 6 wheel.
maxi426
Sep 20, 2018
87
87
The back spacing is different between the early and late wheel. The center being pushed back on the rim makes it look like there is an extra step. It's there on both wheels, just looks more pronounced on the deeper late wheel. Perhaps the early trim ring would work but leave a little extra space between the trim ring and center. Would still like to hear from someone who has actually tried it, and hear how it worked.
19,992
yes the early ones are 4.25 the later are 4 no difference in trim rings
19,992
Yes no difference you can use the same trim ring
19,992
Maybe you have a set of the front wheel drive versions...........:LOL:
kustomkyle
646
47
Perhaps the 1983-1985 Monte Carlo 15" steel wheel, which used trim rings, would present any answers?
Would assume backspacing should be the same as the Olds. The only thing would be for someone with one to measure the lip depths.
