I have a chevy 305 that has a lot of power at high rpm but i want something that has off the line power and some up top instead of nothing off the line, wont even chirp the tires, and then revving past 6,000. The two cams im looking at are:
1.)
Brand:Lunati
Manufacturer's Part Number:10120100LK
Part Type:Camshaft and Lifter Kits
Product Line:Lunati BareBones Camshaft and Lifter Kits
Summit Racing Part Number:LUN-10120100LK
UPC:090127706961
Cam Style:Hydraulic flat tappet
Basic Operating RPM Range:1,000-5,000
Intake Duration at 050 inch Lift:204
Exhaust Duration at 050 inch Lift:214
Duration at 050 inch Lift:204 int./214 exh.
Advertised Intake Duration:270
Advertised Exhaust Duration:280
Advertised Duration:270 int./280 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.420 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.443 in.
Valve Lift with Factory Rocker Arm Ratio:0.420 int./0.443 exh.
Lobe Separation (degrees):112
Or
2.)
Brand:Edelbrock
Manufacturer's Part Number:2102
Product Line:Edelbrock Performer-Plus Cam and Lifter Kits
Summit Racing Part Number:EDL-2102
UPC:085347021024
Basic Operating RPM Range:Idle-5,500
Advertised Intake Duration:278
Advertised Exhaust Duration:288
Advertised Duration:278 int./288 exh.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.442 in.
Valve Lift with Factory Rocker Arm Ratio:0.420 int./0.442 exh.
Which would be better for a 305 with 3.42 gears, rebuilt posi and a 700r4 trans in a cutlass salon?
1.)
Brand:Lunati
UPC:090127706961
Or
2.)
Brand:Edelbrock
UPC:085347021024
