Tune up parts ???'s
dickeymoore
924
Atlanta,Georgia
I just picked up a 1 owner 1988 Monte Carlo SS and want to tune it up what kind of sparkplugs wires are good ones these days, i will be using ac delco r45ts sparkplugs?Thanks
Clone TIE Pilot
3,858
2,611
Galaxy far far away
You also may want brass terminal distributor cap and rotor, O2 sensor, and PCV valve.
69hurstolds
8,196
17,598
You going to modify it or leave it bone stock with GM parts? Makes a difference, IMO. If you go aftermarket, just go down to autozone and tell them what you want and get whatever they give you. Otherwise, you'll need to do a bit of digging.
GM p/n 5613957, aka R45TS spark plugs.
I'd search for the Acniter II series, as those are the OG green ring plugs. But the newer ones are fine, too.
12073928 is a set of spark plug wires. AKA ACDelco #708N
Here's a good set. Made in USA. Although they do not have the rubber tabs like originals for the distributor cap ring.
Cap- 10496801 (Delco #D303A), and finally 19166099
Rotor- 10496798 (Delco # D477)
69hurstolds
8,196
17,598
You want a Delco O2 sensor. AFS-16P, AFS-20 or AFS-21 will work. They changed GM part numbers like they did underwear. Once a week. Get an old school one, not one of the newer jobbies.
PCV- 6487779, Delco # CV774C. Rockauto.com has them for $6 and change, but this one is 9.95 + tax shipped and it's the earlier version it appears.
https://www.ebay.com/itm/1656838070...d=link&campid=5335822911&toolid=20001&mkevt=1
Oct 14, 2008
8,823
7,775
Melville,Saskatchewan
AC Delco stuff has been made in Mexico or China for years. Most of the older stuff is better, if you can find it. The AC Delco aluminum contact distributor cap suck. The Standard, Blue Streak, Accel and even the no name Chinese are better. The wires look OK but there are many other options out there. The AC Delco and Autolite plugs are OK but not as good since being made in China. I like NGK myself. Good luck.
